Volvospeed Forums
Polish
Ben H
Hey
I need to get a polish that will shine up some dull spots on my black 850. The problem is every one i have tried so far only makes the paint dull - the polish works fins on sliver cars....just not my black one!!!
(i was useing the turtle was white polishing compound)
anyone have any ideas??
Ben
I dont really know how to explane..
If i use the polish i have on the black paint it dulls it....a coat of was hides it a bit....but its still there
The fine cut cleaner is not a bad idea...just wanted to know something that is FORSURE safe for black cars befor i spend more money and have more dissapointment
Ben
Ben
show me some pics so that we can see what it is your in need of.
Hey
Ben
It ain't cheap but Zaino is about as good as you can get. You may need to use a good cleaner or clay first but ZAINO works.
I have heard a new product from McGuire's - new generation or 2nd generation works well also.
They have a web site Zaino.com or Zainostore.com I believe. They are in PA.
Hey ben if you use white polish it will shine it up a bit better, but bring out some of the more ugly spot, use a black or darker polish it will hide some of it.
If you are serious about restoring your paint read on....I too have a black Volvo (1998 S70 GLT) and I was considering repainting due to the swirls, scratches- some of which were pretty deep. After speaking to my local body shop heres what I did: Step 1 Wet sand with 1200 grit and soap water Step 2: Wash, dry and apply 3M Perfect-It III Rubbing Compound (#05933) with varable speed buffer at apx.2000 rpm. Use med to light pressure, as compound dries use very little pressure. Step 3: Wash,dry andapply 3M Perfect-It Foam Polishing Pad Glaze (#05996) Apply same way as the rubbing compund but run buffer at 2500 rpm. Step 4: Wash, dry andapply Meguiar's Gold Classic Clear Coat Liquid Car Wax. **It is absolutly importaint to use the recommended pads for the rubbing compound & polish for sucess!!!**
This is a 6+ hour job and can not be rushed. Also, it is notfor the faint hearted as your car will look like a disaster aster you wet sand it but the result is a absolute deep glass-like finish and is well worth the investment, which buy the was is around 100.00 for the compound, polish, 2 pack of foam pads, 1 buffing cloth disk, 1 pkg. of 1200 wet sand paper and around 60.00 for a Chicago varioable speed polisher. Good Luck!
Hey
That would be great if i had a machine to do it......
im just lookin for a less abrasive polish then the turtle wax ive been useing...im gonna try the meguires eventually...
thanks for all the help!!
Ben
i used the MIG diaomnd cut w/ a buffer on my car this weekend then followed up with the #7 show car polish, looks good but i have to wet sand the deeper scratches, id use 2000 grit not 1200
850, I didn't take any before shots. I now wish that I did. Before working the paint job I promissed myself I would never own another black car again, but I'm so satisfied with the results I would have no hesitation whatsoever.
  • Create New...
