Volvospeed Forums
Steering Wheel Removal
dj baracus
i need to replace my steering wheel...im having trouble w/ the 1st 2 screws...doh!
ive turned the steering wheel with screws vertical, but i cannot get enough clearance to get my driver w/ torx bit in...
1. whats the trick? get a shorted torx driver? from where...any tips? ive tried a lisle bit on a 1/4" drive...but bit isnt long enough to reach screw head...
2. any idea what size it is T25, T27, T30...
many thanks in advance!
The torx is a 30, I usually use the long shaft bits, like the one I recommend for the thermostat housing. Make sure you pull the steering wheel out as far as you can and that will help.
thanks rich!, honestly, i didnt know that the steering wheel pulled out!...wow, that helps...
problem now is, i still dont have the right "bit" got to get that T30 long bit...can i get it anywhere...i dont think craftsman makes one?
-thanks again
Guest Guest_r850glt
I went to j home depot & bought a torx set, the folding type for $8, looks like a pocket knife a7 has abourt 8-10different sizes it fits ideal. jUST PULL STTERING WHEEL UP
  • Create New...
