maciekb2002 Posted September 11, 2008 Report Posted September 11, 2008 I am swapping my turbo this weekend and Ecu also will be for sale . I am getting new software, My car did 14,2 , at 105 MPH , and it is 5 speed no LSD. I had 16t on it since October last year, Ecu was programmed for 95 t5-r automatic that car comes with 15g, I had run my car for last year with no problems on white injectors at 21 psi, 16t will hold up about 17-18 psi to red line, car spools fast and it has amazing torque at 3300 to 3700 rpms. It should be little over 300HP at the crank with stock internals,my car keeps up with Evolutin with stage II upgrade that is 345 HP , so assuming that your car should be that fast with this set up , of course I have full 3inch exhaust and Also FMIC .So I want for whole set up $ 650 or I will sell those pieces separately Turbo 16t straight flange with block off plate or CBV your choice $275ECU $370 + SHIPPING White injectors $100this is link just to give you an example , I have couple more clips just search , maciekb2002http://www.youtube.com/watch?v=ce6nQp6S1b4PM me if you interested, I can have turbo pics by this weekend
Black Betty Posted September 11, 2008 Report Posted September 11, 2008 so the tune is set for 18psi on a 16t? or did you just use an mbc to control that
maciekb2002 Posted September 11, 2008 Author Report Posted September 11, 2008 so the tune is set for 18psi on a 16t? or did you just use an mbc to control thattune was for 15g at 18 psi, on orange injectors , So I still run my car at 21 psi on 16t with white injectors, on hwy getting 24-25 MPG
Black Betty Posted September 11, 2008 Report Posted September 11, 2008 ah just realized this is for a 95 damn i was considering it good luck with the sale the ecu is so very temping my 16t begs for it
maciekb2002 Posted September 11, 2008 Author Report Posted September 11, 2008 ah just realized this is for a 95 damn i was considering it good luck with the sale the ecu is so very temping my 16t begs for itit may work it has one more output for temp sensor for EGR , It will not throw CEL , because you don't have that sensor . And yes I was running mbc , never bend a single rod
Yellow95 Posted September 11, 2008 Report Posted September 11, 2008 it may work it has one more output for temp sensor for EGR , It will not throw CEL , because you don't have that sensor . And yes I was running mbc , never bend a single rodIt will throw a CEL becuase the 96-97 has no egr. I know from experience. It wont effect performance however.Gary
