Boosted2003 Posted October 4, 2004 Report Posted October 4, 2004 From what I see the Fuel System Head Design Discplacement Turbo HP1998 Older Older 2.3l 16t 2361999 Newer Newer 2.3l 18t 246-2472000 Newer Newer 2.4l 19t 261-265R = RumorIm most curious about if the 2000 model was truly 2.4l
Guest Guest Posted October 4, 2004 Report Posted October 4, 2004 it's 2.4Lalso, 1998 should be 16t turbo
Johann Posted October 4, 2004 Report Posted October 4, 2004 Im most curious about if the 2000 model was truly 2.4l←Bore was changed from 81 to 83 mm which makes 2435 CC
ROB @ VMS Posted October 4, 2004 Report Posted October 4, 2004 But the strongest bore to have is 81.5mm. Anything bigger you sac wall thickness
Boosted2003 Posted October 4, 2004 Author Report Posted October 4, 2004 But the strongest bore to have is 81.5mm. Anything bigger you sac wall thickness←you said sac. :lol:
